JIRA connector doesn't work anymore
Robby Engelhardt
September 10, 2013
I get an "Internal error validating repository"-error in eclipse while
a) Validating JIRA Repository Settings
b) Syncronizing existing Task Lists from JIRA
Both features already worked for me. But not at the moment.
Here ist the Stacktrace from the error
java.lang.reflect.InvocationTargetException
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
	at org.eclipse.mylyn.commons.ui.dialogs.EnhancedWizardDialog.run(EnhancedWizardDialog.java:138)
	at org.eclipse.mylyn.tasks.ui.wizards.TaskRepositoryWizardDialog.run(TaskRepositoryWizardDialog.java:113)
	at org.eclipse.mylyn.tasks.ui.wizards.AbstractRepositorySettingsPage.validateSettings(AbstractRepositorySettingsPage.java:1919)
	at com.atlassian.connector.eclipse.internal.jira.ui.wizards.JiraRepositorySettingsPage.validateSettings(JiraRepositorySettingsPage.java:448)
	at org.eclipse.mylyn.tasks.ui.wizards.TaskRepositoryWizardDialog.handleExtraButtonPressed(TaskRepositoryWizardDialog.java:96)
	at org.eclipse.mylyn.commons.ui.dialogs.EnhancedWizardDialog.buttonPressed(EnhancedWizardDialog.java:98)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:628)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
	at org.eclipse.jface.window.Window.open(Window.java:802)
	at org.eclipse.mylyn.tasks.ui.TasksUiUtil.openEditRepositoryWizard(TasksUiUtil.java:206)
	at org.eclipse.mylyn.internal.tasks.ui.commands.OpenTaskRepositoryPropertiesHandler.execute(OpenTaskRepositoryPropertiesHandler.java:33)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://2830.fwk1946716086:19/javax/ws/rs/ext/RuntimeDelegate.classtobundleresource://2709.fwk1946716086:3/javax/ws/rs/ext/RuntimeDelegate.class
	at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:116)
	at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:91)
	at javax.ws.rs.core.UriBuilder.newInstance(UriBuilder.java:69)
	at javax.ws.rs.core.UriBuilder.fromUri(UriBuilder.java:80)
	at com.atlassian.jira.rest.client.internal.jersey.JerseyJiraRestClient.<init>(JerseyJiraRestClient.java:64)
	at com.atlassian.jira.rest.client.internal.jersey.JerseyJiraRestClientFactory.create(JerseyJiraRestClientFactory.java:39)
	at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestClientAdapter.<init>(JiraRestClientAdapter.java:159)
	at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.createRestClient(JiraClient.java:179)
	at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.getRestClient(JiraClient.java:154)
	at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.getSessionInfo(JiraClient.java:615)
	at com.atlassian.connector.eclipse.internal.jira.core.JiraClientManager.validateConnection(JiraClientManager.java:156)
	at com.atlassian.connector.eclipse.internal.jira.core.JiraClientFactory.validateConnection(JiraClientFactory.java:167)
	at com.atlassian.connector.eclipse.internal.jira.ui.wizards.JiraRepositorySettingsPage$JiraValidator.run(JiraRepositorySettingsPage.java:537)
	at org.eclipse.mylyn.tasks.ui.wizards.AbstractRepositorySettingsPage$29.run(AbstractRepositorySettingsPage.java:1924)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Root exception:
Here is my eclipse fingerprint
eclipse.buildId=4.3.0.I20130605-2000
java.version=1.7.0_25
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments:  -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Here are the Atlassian-Feature-Details:
  • com.atlassian.connector.eclipse
  • com.atlassian.connector.eclipse.monitor
  • com.atlassian.connector.eclipse.directclickthrough
  • com.atlassian.connector.commons
  • com.atlassian.connector.eclipse.bamboo
  • com.atlassian.connector.eclipse.commons
  • com.atlassian.connector.eclipse.jira
are all 3.2.2.v20130909
The JIRA-Server I try to connect to is v5.2.4.1#846-sha1:7ae4d02
Robby Engelhardt
September 11, 2013
Solved:
  • I took a clean new eclipse kepler
  • didnt install the Atlassian-Jira-plugin via Marketplace
  • did install the new Jira-Plugin (>=Jira5.0) via update-url
and it worked like a charm.
Seams to me there was something odd with my eclipse-installation
