Hi guys, I see that they indicate JIRA will be clustered some time later. Is there any info, or approximate dates or maybe the JIRA release, which could have the future to be clustered?
Ivan.
Data Centre is already available for JIRA, Confluence and Stash, start at https://www.atlassian.com/licensing/data-center
Nic, thanks. I see this comment: https://confluence.atlassian.com/display/JIRA/Installing+JIRA+Data+Center?focusedCommentId=633438491#comment-633438491 "Data Center requires a new license type, however each node in the cluster does not require it's own unique license." Is that right? If so, for example, if we have 2k users we should pay $24k*2, $24k for 1000 users, as stated on atlassian website.
Correct.
Nic, sorry. I must have missed this, we have now users under 2000, does this mean we have to purchase only JIRA Data Center License for only 1000 users ? Thanks.
Only if you have 1000 or less users.
