JIRA issue PDF exporter
Yurii Monakov August 19, 2013
I have a problem exporting issues to PDF from JIRA: all non-english letters are replaced by '#' signs. I guess it is a font problem - font which is used by the exporter does not contain language specific characters.
So is there a way to upload (or specify) font which is used by JIRA's (not Confluence) PDF exporter?
Midori
August 19, 2013
Yurii,
you haven't mentioned what plugin you use to export issues from JIRA to PDF, but I assume this is JIRA PDF View Plugin.
if so, then you need to configure a system font for the plugin that contains cyrillic characters.
follow the Configuring a Custom Character Set guide.
Yurii Monakov August 20, 2013
Thank you Ferenc, I though that PDF export is not a plugin. Its documentation was helpful.
Andrey Markelov
October 21, 2013
Theinvisibleman
August 19, 2013
Hi Yurii,
Could you check and ensure that your JIRA and database is using UTF-8? Also, which version of JIRA are you using?
Hi Joe,
Our JIRA database is using UTF-8 (created with 'CREATE DATABASE jiradb CHARACTER SET utf8 COLLATE utf8_bin'). And JIRA (v. 6.0.5) itself supports Russian language through translation plugin.
PS. JIRA is running on CentOS 6.4 server
