JIRA issue linking to a drive
nidhis September 4, 2015
Hi Team,
We want to be able to link a drive in JIRA where documents will be stored in order that approvers that have received access to that drive from the owner can open all relevant documents
How can we do that?
So far we can link an intranet or homepage  but not sure regarding drive linking.We require it to be used at organisation level
Please let me know at the earliest.#
Nidhi
Nicolas Simon
October 11, 2016
Hello Nidhi,
Since version 5.8.0, the nFeed plugin is able to fetch data from external tools like Google Drive (using its REST API) and display them in fields within JIRA -> https://marketplace.atlassian.com/plugins/com.valiantys.jira.plugins.SQLFeed/server/overview
Nicolas
nidhis September 7, 2015
Hi ,
Please suggest a response.
Nidhi
Deleted user September 7, 2015
There is no way to do that in JIRA
nidhis September 6, 2015
Hi Gabri,
Thanks for the answer.
But i am looking for the way with which i can access a drive from JIRA issue.
Using "URL" i can access any link only.
Please suggest.
Nidhi
Deleted user September 4, 2015
Create a "URL" custom field. It's just like a text field but it's the closest you can get, it does not appear in the "Links" section but it will be displayed if added in the "View Screen".
