JIRA notify to Hipchat room when Components is changed
Hisamitsu Koga
Is there any way to notice a hipchat room when jira component is changed? I'm using this hipchat integration function. https://confluence.atlassian.com/jira/configuring-jira-with-hipchat-296093745.html Hipchat get the notification when issue created or assignee changed. But there is no menu to get the notification when jira component is changed.
e.g. I want to get the notification when component is changed to "development". component : anything  →  component : development
Aleks Yenin (Polontech)
April 19, 2016
Hisamitsu Koga
post function is associated with transition, but component change isn't associated with transition.
April 21, 2016
There is possibility to set up notification scheme on event. When component is added, it is fired issue updated event. https://confluence.atlassian.com/jira/creating-a-notification-scheme-185729542.html
  • JIRA can only send email notifications if SMTP email has been enabled (see Email Overview).
Hisamitsu Koga
If Component/s value is changed, Issue Update event will occur, but how can we send notification
to HipChat room at that time by Notification Scheme?
