JIRA on-premises default installation pre-installed plugins
dhaval soni
April 2, 2013
Which are the plugins are pre-installed with JIRA on-premises default insallation ?
Nic Brough -Adaptavist-
April 2, 2013
The only plugins you need worry about are the ones you've chosen to install in your OnDemand account.
The plugins you get with downloaded Jira enable Jira to work as a standalone system. The plugins in OnDemand are slightly different because they enable integrations with the rest of OnDemand. There's no point in comparing the list - the ones you don't need aren't in standalone, and the ones you need to run Jira properly are all in the download version.
And, again, if you're that worried about it, your best bet is to download the version you want, run it, and test turning things off (although the list you've given is pretty much "core" so turning them off is going to break things)
dhaval soni
April 2, 2013
ya, right.
Actually, i have considered most of plugins which are enabled in User installed plugins and using in current instance.
But i was not sure about some of plugins usesage which are shown in system/user installed plugins list in my on-demand instance. i was not clear these plugins really needs or not or will be given as default pre-installed plugins into on-premises instance.
Some of such plugins are as below:
Atlassian OAuth Service Provider SPI
Atlassian Pretty URLs Plugin
Atlassian Remotable Plugins - Plugin
Atlassian Remotable Plugins - Sisu Extender
Atlassian Remotable Plugins API - Public API
Atlassian Remotable Plugins API - Public SPI
Atlassian REST - Module Types
Atlassian Soy Templates - Plugin
Atlassian Template Renderer API
Atlassian Template Renderer Velocity 1.6 Plugin
Atlassian UI Plugin
Atlassian Universal Plugin Manager Plugin
Atlassian WebHooks Plugin
aui-qunit-plugin
Browse Project Operations Sections
Confluence XML-RPC Java Client - Plugin
Content Link Resolvers Plugin
Thanks.
April 2, 2013
So, your question is actually:
What plugins have I got installed in my OnDemand instance that I will need to think about carrying over to my self-hosted installation.
The answer to which is really that we can't tell you because we don't know which ones you've enabled in the plugins screen in your installation (For "budgeting", it's even easier - you'll have the costs of each one you are paying for listed in your OnDemand account invoices)
dhaval soni
April 2, 2013
apologies for less description.
we are planning to migrate from on-demand to on-premises and need to find whcih plugins are not available by default in on-preminses so, those can also include in budget.
In AOD comes pre installed plugins as given in below link: (but could not found for on-premises):
https://confluence.atlassian.com/pages/viewpage.action?pageId=315326753&from=PQIYDw
So, It looks like, On demand JIRA's system plugins will be default given in on-premises.
Thanks.
April 2, 2013
Pretty much as Onkar says.
I can't actually imagine a situation where this information is useful to you while you have no access to a local installation of Jira where you can look for it.
First of all, you haven't told us what version of Jira you're interested in, and the plugins vary by version, so we can't answer you anyway. Secondly, why would you expect us to spend time firing up a copy so that we can go into the plugin page and copy and paste the information there and post it, only to find out you probably have loads more questions about the list that are answerable by more digging?
I'd suggest you run a development system up, or an evaluation, and look for yourself - whatever your reasons for asking this question, I can't think of a reason why you wouldn't end up doing that soon anyway.
Please, do the basics before asking questions and expecting us to do your work for you.
dhaval soni
April 2, 2013
I don't have setup on-premises JIRA , we are using JIRA On-demand.
I want to figure out , which are the plugins existed in on-premised JIRA by default.
Onkar Ahire
April 2, 2013
You will see category's in Manage Add-ons, The question as per my understanding you will see System plugins , I think this is the correct answer of your question.
Another categories like user installed, paid atlassian, action required is not comes with JIRA as per my knowledge.
Regards
Onkar Ahire
