JIRA project doesn't exist or you don't have permission to view it when reordering issues
Ellen Beentjes
I insert a JIRA filter list view and can see all the issues.
However if I click on one of the column headers to re-order the data I get the above error message.
JIRA project doesn't exist or you don't have permission to view it.
Does anyone know why this is happening and how I can solve this?
Angélica Luz
November 28, 2018
Hi Ellen,
Are you facing this issue on a filter in Jira or using a Jira filter on Confluence?
Would it be possible to send us a screenshot showing where this error is appearing?
Angélica
Ellen Beentjes
Seems to be solved now. Thanks!
Like Angélica Luz likes this
Martin Greksa
March 28, 2019
Hi, please provide also a solution. It would be very helpful for other people who encounter the same problem.
Thank you.
Like Deleted user likes this
Laurie Planes@sickleave July 26, 2019
Hi, Same issue here. For me it happens while using the jira filter on Confluence.
I tried filtering on one project only (I can create tasks on this project in jira)
I'm interested in a solution too :)
Best,
Laurie
Angélica Luz
July 29, 2019
Hi Laurie,
Can you please confirm with the administrator if you have access to see all the tickets in the project? Maybe the project has Issue security and the tickets are not available for everyone to see.
Also, I would like to confirm if the message is happening when you try to filter one of the columns. I found a bug but it only happens when trying to filter by Organization:
- https://jira.atlassian.com/browse/CONFCLOUD-65463
If it's not this bug, can you please let us know all the steps you are following until the message appears?
Angélica
Laurie Planes@sickleave July 29, 2019
Hi @Angélica Luz
Thanks for answering :)
The error message appears only when I try to sort by clicking a column (any column). So I guess it's the same as https://jira.atlassian.com/browse/CONFCLOUD-65463.
Like Ellen I inserted a filter list view, and it seems to work (see my 1st screenshot), but if I try to sort the issue I get the error message in my second screenshot.
So is it the known bug you mentionned or is it worth that I ask my administrator? I'm not sure there can be an access issue if I can see the tickets (displaying the list works fine) and not sort it.
Laurie
Angélica Luz
July 30, 2019
Hi Laurie, I just tested and confirmed that the bug only happens when filtering the column "Organization", it should not happen when filtering, for example, reporter, created or summary.
If you click on "View these issues in Jira" and you are able to see all the tickets, we can confirm that is not related to permission.
Have you tried to create a new page and add the filter to test?
Is there any other user with the same level of access that you have, facing this issue?
Laurie Planes@sickleave July 31, 2019
Hi  @Angélica Luz ,
I confirm clicking on "view these issues in Jira" works properly :
Also, I don't have the "Organization" field in my list :I also confirm that users use the same profile type encounter the same issue.
I tried inserting the same filter on the different page. Same result : I can see the issues list but when I click on a column to sort I get the error message.
Laurie
Angélica Luz
August 2, 2019
Laurie, we tried to replicate this issue on two different instances but we couldn't replicate.
We will need to further investigate what is happening, so I created a ticket with our support. so if you allow, they can access the instance and check the details in order to find what is causing this.
You should have received an email and soon someone will contact you.
Once the ticket is resolved, feel free to share the resolution here to help other community members that may face the same issue.
Hope you have a great weekend!
Andrew Tagg
Why is this the accepted answer? Issue is not resolved
Like DKK98 likes this
Greg Johnson
I have the same bug appearing, and this is not a solution.  angelica is there anything we can do?
Felix Petsovits
January 26, 2022
Hey all.
Not sure if this is the same issue that you're all experiencing but it might be... sounds at least similar... so here are my findings:
My problem:
I took an old project in JIRA that needed a do-over, renamed it, gave it a new key and also created a new filter that I based my project on. Then I went to the board I created and I saw all the tasks, but I had this notification on the bottom of the board. So far so good.
My colleagues then tried to open the board and couldn't see anything other than this warning:
Alt text:
board not accessible.
It seems this board doesn't have an assigned location. You can ask your board administrator to assing it to a project or user.
Then I found this thread here and saw that filters might play a role to be able to view the board - most likely because the board is based on the filters. So I looked at my newly created filter for the already previously existing board. In the filter I had only changed the project key, but in the end it was a completely new filter that I used. And I had not given any permissions for it to anyone.
So I went into my filter, I gave the whole organization permission to see the filter (but could probably also be done on an individual level) and everybody was able to see the board.
6 votes
Marc
Referring to this ticket https://jira.atlassian.com/browse/CONFCLOUD-53559
I was able to resolve this by removing the order by clause in the JQL.
FYI this worked on a data center instance so it probably isn't just cloud related.
This will not be an acceptable solution if sorting by is important to the content you want to display.
Matthew Lange
September 29, 2020
Thank you for this. this is the solution that I was looking for.
Kyle Hardin
This was the solution in my case as well, thank you.
Kyle Hardin
It looks like the bug has to do with ordered fields that consist of more than one word.  You can get around this by referencing the field ID instead of the name, like this:
ORDER BY cf[11800] ASC
You can find the field ID by browsing to the custom field in Jira admin settings, click the cog icon, choose "configure", then look for the string of numbers at the end of the URL on the configure page.
Like Greg Johnson likes this
Deleted user September 23, 2022
Still doesn't work....I'm using 2 sorting orders..
statuscategory DESC, cf[10014] asc
and when I apply that JQL in the JQL macro, I still the error mentioned in OP above.
Faiz Aziz
August 27, 2024
Refer to the Filter Visible Setting, If access User doesn't have access then this error appears however you are the admin, member or any kind of access of the baord or project.
Lucas Haidar
October 17, 2019
I am facing the same issue.
However I noticed that it seems to be related to the language of the header.
By defaut it is set as English while the content of the ticket is in another language (FR) for me.
For some reason (that I can't replicate), the headers switch to French and suddenly I could sort with no issue. Unfortunately, after refreshing it switched back to EN and it doesn't work anymore...
Could you maybe try to fix this?
Thanks!
Lucas
Lucas Haidar
October 17, 2019
Fix found... Simply change confluence default language to match Jira's.
Suddenly all works fine.
How does that happen?
