JIRA to Quality Center integration question
Christine Edwards
September 26, 2011
Does anybody know if the Orasi bridge or the Go2Group plugin will integrate stories from JIRA to Quality Center.
Thank you in advance for your response,
Christine
Jobin Kuruvilla [Adaptavist]
November 27, 2013
Go2Group has a plugin (JaM) and a standalone product (ConnectAll) that integrates JIRA and QC and both supports all issuetypes. You might want to do an eval.
Julian
November 27, 2013
Hi Christine,
About the integration, I have founded a plugin that you might could use for the integration https://marketplace.atlassian.com/plugins/hpsync-plugin.xml
But, most comment advise the viewer to check directly on the ORASI site, which inlcude more details about the plugins. You may check the site here http://www.orasi.com/testing-solutions/Pages/JIRA_Bridge.aspx
Hope this helps and all the best.
