I want to be able to create a issue hierarchy as EPic-> Feature -> Story. I have version 6.2. Is it doable?
No it's not. The only hierarchy possible is task -> subtask. But there is a way to bypass this: using issue links. You can use default link type "relates to" or create a new one, and then links Epic/Feature/Story together.
Example: Story#1 relates to Feature #1 relates to Epic #1
Fred
