I need to add validation if custom field is not equal to some of its options. If so, then another field becomes a mandatory field.
We tried the following SIL code but it is not working
string errorMsg = "Field was not initialized!";
string test = customfield_11700;
if ((test != "No") || (test != "Neither"))
    if(!hasInput("Mandatory Field"))
   return false, "Mandatory Field", errorMsg;
		I'm not sure if I understand correctly but you have made a mistake in the logic condition. You're getting success if test is either different then "No" or "Neither". So when test equals "No" it IS different then "Neither", or the other way around, you're getting a success  In fact you're always getting a success with this condition (the only possibility for the failure would be if test would be equal to "No" and "Neither" IN THE SAME TIME, and that is not possible).
Try this:
boolean success = true;
if ((test == "No") || (test == "Neither"))
	if(!hasInput(customfield_XXXXX)) //XXXXX is the id of your "Mandatory field"
		success = false;
return success, customfield_XXXXX, errorMsg;
EDIT: corrected mistake in code.
Hi Blazej! Thanks for your response.
While trying your SIL, i am able to validate my customfield. If test = "No" or test = "Neither" gets validated, then a field has to become mandatory. But that is not happening. How can we do that?
I looked into the documentation and it says that hasInput() must be called with customfield_XXXXX as a parameter. I've tried the script locally, yet it still fails, with some odd results.
I'll try to look at it a bit deeper, and if I will not find an error I'll raise a support ticket at producer's tracker.
If you want you may try alternate method to work this out:
    if(isNull(#{Mandatory Field}))
        success = false;
	else
		success = true;
return success, #{Mandatory Field}, errorMsg;
