JIRA6 spacing between elements
Maurycy Widera
In JIRA6 spacing between elements is much bigger reducing the usability.
Is it possible to reduce the spacing between elements?
Spacing
Maurycy.
Peter Van de Voorde
A handy work around might be to use the ctrl and - buttons to make your browser display everything smaller (you can go back to normal by using ctrl and + or ctrl and 0(zero) )
Just an idea,
Peter
Maurycy Widera
Peter,
Well.... thanks for the workaround but this doesn't actually resolve the issue :(
Mau.
Maurycy Widera
On one hand we can claim more space when viewing list of issues by hiding filters, etc. but the actual amount of visible information when creating new issue is much lower.
Christian Czaia [Decadis AG]
August 26, 2013
My guess would be that this was the intended behaviour in JIRA 6 so reducing the space would mean to alter core code....
