×Using JMCF, is it possible to use the WAS and CHANGED operators for custom fields?
Ex, "Custom field" WAS "my value"
you cannot use WAs and CHANGED for calculated custom fields. Not sure you can even use them for any custom field for that matter.
You might want to submit a ticket with the vendor to double check.
https://jqlsearchextensions.atlassian.net/servicedesk/customer/portal/2
Usually custom fields don't have these options.
-Ben
