JMWE On post function create issue, assign to Project based on custom field input
Zac Boyd
Using Groovy for the first time through JMWE
Setting up a post function that will create a new issue and assign it to a Project using a custom field (Single Select List) value.
Tried:
x = issue.get("customfield_1000")
issue.setProjectObject(x)
Also tried:
def customField = customFieldManager.getCustomFieldObjectByName("Project")
def newValue = issue.getCustomFieldValue(customfield)
issue.setProject(newValue)
All with no luck. Thanks for the help in advance !
Zac Boyd
Logged a ticket with the @Appfire Support team who answered the question. Thought i'd repost the answer to let others know !
In JMWE you could use the “Calculated” project option on the Create/Clone Issue(s) post-function. Please refer to the example below:image-20230127-145733.png
In the example above, the custom field type is a project picker. Then you can decide what will trigger the post-function hence the issue copy/clone.
For example, you could use Event Based Actions to execute the post-function once a specific issue field value is changed or when the issue itself is transitioned.
Vamsi Kandala
January 23, 2023
Hi @Zac Boyd
Welcome to the community!
If I understand you correctly, you want to create the issue dynamically in another project say ABC based on the selection of custom field value in project XYZ.
Did you try considering doing this using automation rules?
Vamsi
Zac Boyd
Yes i have,
As a work around we have a manual trigger set up to link to one Project, but we have over 15 projects currently and trying to create a way to set it based off the field doesn't work in Automations.
Tried:
Trigger= When Value changes for Field X
Action= Then Create a New issue,
Project = "Same project as trigger" ( This is then run as the project the automation runs from)
I have found no better options to select a custom field dynamically in automation
Vamsi Kandala
January 23, 2023
Hi @Zac Boyd
Automation rules are generally specific to the related projects only.
If you want to create an issue in Project XYZ after an issue is created in Project ABC, you are accessing multiple projects.  So, you will have to create the automation rule in the global level.  That way, you will have option to select the specific project that you want.
Note that, the owner of the automation rule should have related permissions in all the affected projects.
Hope this helps.
Vamsi
Zac Boyd
Sorry, i should've been a bit more clear, the above is at the Global level.
I cannot set the Action to choose a dynamic field. You can only either state a specific project or "current project" or "trigger project"
The reason i want to set it as dynamic is that we are expecting a large influx of Projects to be created so i want to avoid creating a Multiple automations each time a Project is created.
Vamsi Kandala
January 24, 2023
Hi @Zac Boyd
Understood.
I have checked different things and did not work for me either.  I am not completely sure whether it is possible using post functions.
Please check with Atlassian support if you have not already contacted them.  And please update here if you are able to find the solution.
Vamsi
SERVER
