JMWE Transition Issue on Custom Field
Jack Harrison
March 15, 2017
Hey,
I am trying figure out how to transition an issue using a custom field, the custom field is a Select List (single choice) named "Branch". I am not sure where I am going wrong and after reading the documentation I am still lost. All I have so far is {{ issue.fields.branch == "Trunk" }}, this field is also normally empty, it is defined in the same transition as this post function is running I am not sure if that matters or not.
Any help would be greatly appreciated.
Jack
David _old account_
March 15, 2017
Hi Jack,
as documented here, since your custom field is a Select List field (single choice), the field value is actually an object, of which you want to access the "value" field:
{{ issue.fields.Branch.value == "Trunk" }}
(I also put an uppercase B in the field name since that's what you wrote in your question)
Jack Harrison
March 16, 2017
Hi David,
Thanks so much for your response it worked like a charm smile. I must have somehow missed that part of the doc, I have bookmarked it now.
Thanks for your help.
Jack
