JQL Help
PhilSpo
May 15, 2020
Okay so i have the following JQL:
(category = "Customer Projects" OR category = "Shared - Customer Project Workflow") AND labels = re-work
and it brings back the following results:
What i need to do now is add to the JQL so that it only brings back all those with a 'Re-work label' as Empty (None) as some of these are populated.
If i add AND "Re-work Label" is EMPTY onto the end of the JQL it brings back no results. I have tried different ways of adding that final part into the JQL with no luck.
Does anyone know the correct answer please?
Phil
3 votes
Christian Czaia _Decadis AG_
May 15, 2020
Seems like that's the correct JQL. Is Re-work Label a custom label field? Is that a new field and maybe you haven't reindexed after adding the field to Jira?
What if you turn around the bit to state  "Re-work Label" is NOT EMPTY? Do you get the expected results?
Cheers
PhilSpo
May 15, 2020
Thank you Christian, Yes it was the lack of the Re-index that caused the problem.
School boy error on my part.
At least i know my JQL is fine :)
Thanks Again for your help.
Cheers
Phil
Like Ingo Mohr likes this
Ignacio Pulgar
May 15, 2020
Hi @PhilSpo ,
As a side note, while this part of your query contains absolutely correct syntax:
I'd recommend this alternative but shorter way to retrieve the same issues:
category in ("Customer Projects", "Shared - Customer Project Workflow")
Best regards
Like # people like this
Ingo Mohr
Hi Phil,
if you add
, this probably returns an empty result because the entries all have a "Re-work Label" value - which is "None".
If you tell me what values "Re-work Label" can have and what type the field has (e.g. String, Enum, ...), I'll try to build you JQL query.
However, I am not sure I understand what you want to see exactly:
Do you want to see all issues (in one of the two categories AND label "re-work") that do have a "Re-work Label" value other than "None"?
Cheers
Ingo
PhilSpo
May 15, 2020
All sorted now Ingo, but thank you for the kind offer.
Cheers
Phil
Sanjana _Alacriz_
Hi @PhilSpo
Not sure if I understood your problem correctly. If you are trying to fetch all issues where there is no Re-work label, then you should be using below JQL
(category = "Customer Projects" OR category = "Shared - Customer Project Workflow") AND labels != re-work
--Sanjana
