×Okay so i have the following JQL:
(category = "Customer Projects" OR category = "Shared - Customer Project Workflow") AND labels = re-work
and it brings back the following results:
What i need to do now is add to the JQL so that it only brings back all those with a 'Re-work label' as Empty (None) as some of these are populated.
If i add AND "Re-work Label" is EMPTY onto the end of the JQL it brings back no results. I have tried different ways of adding that final part into the JQL with no luck.
Does anyone know the correct answer please?
Phil
Seems like that's the correct JQL. Is Re-work Label a custom label field? Is that a new field and maybe you haven't reindexed after adding the field to Jira?
What if you turn around the bit to state "Re-work Label" is NOT EMPTY? Do you get the expected results?
Cheers
Thank you Christian, Yes it was the lack of the Re-index that caused the problem.
School boy error on my part.
At least i know my JQL is fine :)
Thanks Again for your help.
Cheers
Phil
Hi @PhilSpo ,
As a side note, while this part of your query contains absolutely correct syntax:
I'd recommend this alternative but shorter way to retrieve the same issues:
category in ("Customer Projects", "Shared - Customer Project Workflow")
Best regards
Hi Phil,
if you add
, this probably returns an empty result because the entries all have a "Re-work Label" value - which is "None".
If you tell me what values "Re-work Label" can have and what type the field has (e.g. String, Enum, ...), I'll try to build you JQL query.
However, I am not sure I understand what you want to see exactly:
Do you want to see all issues (in one of the two categories AND label "re-work") that do have a "Re-work Label" value other than "None"?
Cheers
Ingo
All sorted now Ingo, but thank you for the kind offer.
Cheers
Phil
Hi @PhilSpo
Not sure if I understood your problem correctly. If you are trying to fetch all issues where there is no Re-work label, then you should be using below JQL
(category = "Customer Projects" OR category = "Shared - Customer Project Workflow") AND labels != re-work
--Sanjana
