My team is developing a connect app, where we store data in the Jira issue properties, and now we want to make the issues filterable with these properties, so I looked into the connect module: jiraEntityProperties and I did it, so I tested it and it did work, kind of, thats where my problem comes in place. I created an issue, then I set the issue property and tested the jql, and it worked, then I tried to override the old property with a new one, that worked, and then I tested the jql again, and that didnt work, but it not only didnt work, it showed me my issue when I did the jql from before updating the issue property, so I thought maybe it gets cached or something, but after waiting round about 12h it still doesnt work correctly. So I wanted to ask if anyone else knows what the case is here, for you to understand it further here is my descriptor and what I have set the first time and the secound time for the issue as well as my jqls:
Descriptor “jiraEntityProperties” module:
jiraEntityProperties: [
key: 'test-entity-property',
value: 'test Index'
entityType: 'issue',
keyConfigurations: [
propertyKey: SETTINGS.constants.PROPERTY_PREFIX + 'test',
extractions: [
objectName: 'v',
type: 'number',
alias: 'version'
objectName: 'items.userId',
type: 'string',
alias: 'userId'
objectName: 'items.threads.threadId',
type: 'string',
alias: 'threadId'
The First Issue Property I set after issue was created:
"v": 3,
"items": [
"userId": "ABC",
"threads": [
"threadId": "123"
JQL test that showed the correct issue for these jqls:
threadId = “123” OUTPUT: This Issue
userId = “ABC” OUTPUT: This Issue
version = 3 OUTPUT: This Issue
userId = “Test” OUTPUT: No Issue
threadId = “Thread1” OUTPUT: No issue
The Updated Issue Property with which I overwrote the first property on the exact same Issue:
"v": 3,
"items": [
"userId": "Test",
"threads": [
"threadId": "Thread1"
"threadId": "Thread2"
Second JQL tests which didnt show this issue:
userId = “Test” OUTPUT: No issue
threadId = “Thread2” OUTPUT: No issue
So I hoped this helped for your understanding of my problem, I just want to know why this is happening and how to fix this or if it is just a indexing/caching thing, where atlassian indexes it every 24h or something like that.
I tried it the other way around too with a new issue, and it worked the exact same way, so I dont think my descriptor module is wrong 😕
PS: I also wrote the technical support about it, but maybe someone in the community knows this and answers a bit quicker :)
Hi @Sebastian Rosenkranz and welcome to Community
You'll find more help by asking this question on the Developer Community: https://community.developer.atlassian.com/
