JQL Query Dummies Guide? Is Not does not seem to be working
Stuart Wildman
March 29, 2015
Hi
I can't get a simple JQL Query to work this morning.
I want to filter out all issues of Status closed.
So i would expect
AND status is not .....   to work
I have tried
  • is not closed
  • is not "closed"
  • is not (closed)
  • is not ("closed")
Any ideas?
Also if there is a great dummies to experts guides
Thansk
joachimbollen
March 29, 2015
Hi Stuart,
status != Closed
should do the trick for you. The autosuggest functionality of the search for issues - advanced screen really helps for finding these syntax tips.
MattS
March 30, 2015
Status is not in (Closed)
should work as well
Stuart Wildman
March 29, 2015
Yes that worked.
The auto suggest offered up that in the list, 'is not' did look the best option. Obviously not.
