JQL difference between UpdateDate and Createdate
Steve Harrison October 15, 2021
I am trying to add a query to my dashboard that shows the time taken between creating a JIRA ticket and Updating (closing) it. The SQL brain in me wants to just use a minus function but in JQL I just can't work this out. Any ideas?
For example:
CreatedDate = 10/Oct/21
UpdatedDate = 15/Oct/21
Days Elapsed (or whatever I call it) = 5 days
thanks
steve
Suvradip Paul
October 15, 2021
Hi @Steve Harrison ,
Thanks for posting ad welcome to the community.
I think you need Scriptrunner dateCompare - https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html.
Please check and let know your feedback.
Thanks I have installed scriptrunner and applied the trail license but it fails to enable. Telling me to refer to the logs but I don't know where the logs are generated
Suvradip Paul
October 15, 2021
I Think you are referring for Audit logs, please check this  - https://docs.adaptavist.com/sr4jc/latest/best-practices/audit-logs.
Please check this for Execution History - https://docs.adaptavist.com/sr4jc/latest/best-practices/execution-history.
Please check this for most recent logs for script executions - https://docs.adaptavist.com/sr4jc/latest/best-practices/script-logs.
Let me know if that helps.
Steve Harrison October 16, 2021
This hasn't helped.  I have added ScriptRunner to my JIRA instance but it looks like I need to enable to. When click it then just takes a long time trying to do something then returns an error and tells me to look at the logs. Which logs? I have no idea where they are? This is extremely frustrating.
Steve Harrison October 18, 2021
Ok a change of tact because I really don't see why I should not be able to do this in JIRA without ScriptRunner.
How about adding a custom field that returns the difference in days between two dates. Sorry I not familiar with JIRA but surely I can achieve this by creating a custom column and rule. I just can't fin where to create a rule.
Rule should be UpdatedDate - CreatedDate  = x days based on the JIRA status.
Any thoughts?
thanks
