What is the difference between "resolution =" and "resolution changed to" when running JQL.
project = KSENROLL AND resolution = Fixed AND fixVersion = M7
Returns 1287 Issues
project = KSENROLL AND resolution changed to Fixed AND fixVersion = M7
Returns 1330
Ben
The "CHANGED
" operator is used to find issues that have a value which had changed for the specified field.
This operator has the following optional predicates:
AFTER "date"
BEFORE "date"
BY "username"
DURING ("date1","date2")
ON "date"
FROM "oldvalue"
TO "newvalue"
check the following document to get knowledge on advace searching
https://confluence.atlassian.com/display/JIRA/Advanced+Searching
the former one is where the resolution is currently set to fixed. The latter one is any tickets that has had resolution as "fixed" but could now have a different value.
You can also see by example what characterizes the difference by trying these two queries:
project = KSENROLL AND resolution changed to Fixed AND fixVersion = M7 AND NOT resolution = Fixed project = KSENROLL AND resolution = Fixed AND fixVersion = M7 AND NOT resolution changed to Fixed
ah, Thank you!
