How can write a jql where I want to fetch the child issues for which custom field are empty in the parent issue.
Note: Those custom fields does not exist in the child.
Hi @Amzad Khan ,
@Laurie Sciutti is correct. You can use the subtasksOf JQL function in the Enhanced Search feature of ScriptRunner for Jira Cloud.
We're extremely close to releasing a dedicated childrenOf JQL function, which can be used for any child issue type:
issueFunction in childrenOf("customfield is EMPTY")
Please don't hesitate to reach out if you have any questions :)
Reece
Hi @Amzad Khan
I’m Charlotte, a support engineer at Appfire and I’m here to help you.
Unfortunately, using vanilla JQL, you’ll not be able to do it dynamically.
In the app where my team works, JQL Search Extensions for Jira, you can use this query to find, for example, Sub-tasks for which a custom field is empty in the parent issue:
issue in subtasksOfParentsInQuery("customfield is empty")
Or this one to find Epics' children for which a custom field is empty in the Epics:
issue in childrenOfEpicsInQuery("customfield is empty")
Please contact our support if you have any other questions about this query.
We’ll be happy to help you!
Hi @Amzad Khan
unfortunately, this is trickier than one might think; as a hierarchical query, it would really require some kind of join or subquery, which isn't available in plain Jira/JQL.
A few directions forward:
If you want to run your search dynamically, without manually "stitching" two queries together, you'll need extra tooling:
Hope this helps,
Best,
Hannes
Just to expand on the last point, this is how this would look in the app that my team and I are working on, JXL for Jira. Put simply, you'd create a sheet with all issues that are potentially relevant to you, enable the default issue hierarchy (that's just one click), and then use JXL filtering capabilities to narrow down to the issues that you care about:
Once you have your list of issues, you can work on these directly in JXL (much like you'd do in e.g. Excel or Google Sheets), trigger various operations in Jira, or export them for further processing.
Any questions just let me know!
Hi @Amzad Khan ~ do you use ScriptRunner? If so, and assuming child issues are sub-tasks, the following should work:
issuetype = Sub-task AND issueFunction in subtasksOf("customfield is EMPTY")
