JQL for Card Color if Issue has SubTask of a certain type
Stephen Herrick February 27, 2020
I'm trying to figure out how to write the JQL to set the card color if the Issue has a subtask that is a certain type ("Fault" in this case).  Here are some that I tried out and neither seem to work.
linkedIssue in(issueType = Fault AND status != Done)
subtasks in(issueType = Fault AND status != Done)
 Anyone get any success with something like this?
Parvaneh Zand
February 27, 2020
That looks like it would help but that is a paid app.  I was hoping to find a solution using the built in functionality of Jira Cloud.
Parvaneh Zand
February 29, 2020
As much as I know there's no way to do this without a plugin. Your question needs a subquery inside the parentheses, but built in functions don't support it:
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-functions/
Stephen Herrick March 2, 2020
That is what I thought.  Thanks for your help.
Daniel Turczanski - JQL Search Extensions
Hi @Stephen Herrick ,
It's not a native solution but you can try our app JQL Search Extensions. It supports subqueries for links, subtasks and epics.
