×Hi,
I'm trying to read a field value from an issue in a project.
I know the project name, but the issue has to be looked up by one of its fields.
Using Automation 'Lookup Issues' action I type the same JQL used in the advanced search:
project = myproject.
Advanced search returns 2 issues, the Lookup inside Automation returns zero.
I've tried double quotes, project name, project key, project id. Nothing works.
Any idea how to get there?
Thank you.
Hi @Inna S
For a question like this, please post images of your rule and the audit log details showing the execution. That will provide context for the community to offer suggestions.
Without that information, I wonder...
Your JQL references a Jira project. Is your rule defined in a different project? If so, the rule cannot "see" the issues as they are out of scope.
Or if your rule is defined as multi-project, is the project referenced in the JQL defined in the rule details/configuration?
Hi @Bill Sheboy
The rule is defined as a multi-project, listing both, the project where the automation will run and the other project where the issue of interest resides.
But the query generated has the "original" project, and the one I'm interested in.
(project in (10007)) AND ((project = MYPROJ))
Please try changing that to include both projects using IN:
project IN (10007, MYPROJ)
Otherwise no issues will match as they cannot be in both projects at one time.
I am not following how that can be the case...Would you please post images of
Thanks!
No, reduced to the single (project = myproj).
