JQL using JIRA API in Python
Harshita G
April 10, 2023
Hi I am trying write a JQL using the API in python to get the data from the tickets from a particular board, I want to add date variables so that we can get the data for user entered dates. I am new to using the API so unable to figure out how to do this. I will be grateful for any help, Thanks in advance. I tried using the following which is giving me error -:
project_issues_specific = jira_instance.get_all_project_issues(project="MED", fields=["description", "summary"])
the above is working but giving me the first 1000 when the board was created, I also tried
jira_instance_1 = jira_instance.jql(project = "PROJ1" AND "Epic Link" = EPIC-123 AND issuetype = Story ORDER BY priority DESC, updated DESC)
jql_query = project = MED AND issuetype in (Task,Story) AND "Epic Link" = "MED-098" AND updated >="-6M"
both of these are giving me syntax errors.
Jared Kells
I think the JQL should be in a string and I don't see any quotes around them, is it a python syntax error?
Something like "project = \"PROJ1\" AND \"Epic Link\" = EPIC-123 AND issuetype = Story ORDER BY priority DESC, updated DESC"
I could be misunderstanding but hope that helps!
Harshita G
April 14, 2023
Thanks Jared, yes it was a syntax error, thanks for helping me out.
