I try to join issues from two project - Projec1 and Project2.
But I want to see only those issues from Project2 which have the same values in custom field as searched issues in Project1.
Is it possible to create that filter?
Thank you
Hi Katarína
Native JQL seems won’t support functions as you mentioned , reference ticket .
If you are running an on-premise instance , you can try sql query as workround.
Best Regards,
Tom Zhu
