Java Melody Data base monitoring help
Fabio Manzoni
Hi Guys,
I'm traying to configure Java Melody dabatase monitoring without sucesss. I followed the instructions of Java melody wiki https://github.com/javamelody/javamelody/wiki/AtlassianPlugin.
Also I found this question https://community.atlassian.com/t5/Jira-questions/How-to-configure-Java-Melody-in-JIRA-5-or-6-so-it-does-monitor/qaq-p/7319 without success again.
Can someone help me?
This is a Jira 7.1 and MySQL, its a test envinronment.
server.xml
<Engine name="Catalina" defaultHost="localhost">
<Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false">
<Resource name="jdbc/jiradb" auth="Container" type="javax.transaction.UserTransaction"
username="xxxx"
password="xxxx"
driverClassName="com.mysql.jdbc.Driver"
url="jdbc:mysql://localhost/jiradb"
maxActive="20"
maxIdle="10"
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
</Context>
</Host>
dbconfig.xml
<?xml version="1.0" encoding="UTF-8"?>
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>mysql</database-type>
<jdbc-datasource>
<url>jdbc:mysql://localhost:3306/jiradb?useUnicode=true&amp;characterEncoding=UTF8&amp;sessionVariables=default_storage_engine=InnoDB</url>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<username>xxxx</username>
<password>xxxx</password>
<pool-min-size>20</pool-min-size>
<pool-max-size>20</pool-max-size>
<pool-max-wait>30000</pool-max-wait>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-max-idle>20</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
<pool-test-on-borrow>false</pool-test-on-borrow>
<pool-test-while-idle>true</pool-test-while-idle>
<validation-query-timeout>3</validation-query-timeout>
<schema-name>public</schema-name>
<jndi-datasource>
<jndi-datasource><jndi-name>java:comp/env/jdbc/jiradb</jndi-name></jndi-datasource>
</jndi-datasource>
</jdbc-datasource>
</jira-database-config>
Fabio Manzoni
Hi everyone,
For configure your Java Melody database monitoring in a SQL Server, take a look on this example.
Dbconfig.xml
<database-type>mssql</database-type>
<schema-name>Jira_Schema</schema-name>
<url>jdbc:sqlserver://localhost:1433;databaseName=jiradb</url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
<username>xxxxx</username>
<password>xxxxxx</password>
<jndi-datasource><jndi-name>java:comp/env/jdbc/JiraDS</jndi-name></jndi-datasource>
server.xml
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="jdbc/JiraDS" auth="Container" type="javax.sql.DataSource"
username="xxxxxx"
password="xxxxxx"
driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://localhost:1433;databaseName=jiradb"
maxActive="20"
maxIdle="10"
validationQuery="select 1"
Sylvain Leduc
Hello @Fabio Manzoni
So you need to keep both <jdbc-datasource> and <jndi-datasource> in the dbconfig.xml + add the resource in server.xml ?
https://github.com/javamelody/javamelody/wiki/AtlassianPlugin says to replace it : "To configure JIRA with a datasource, replace in the jira-home/dbconfig.xml file "<jdbc-datasource>...</jdbc-datasource>" with "<jndi-datasource>"
Thanks.
Sylvain
SMS
March 13, 2018
Fabio,
Can you tell us exactly what is not working and error messages that you see?
Shannon
Fabio Manzoni
Hi Shannon,
Thank you for your attention. It's a test environment and I solved the problem in MySQL database with this information below. But now I try to use the same configuration to Microsoft SQL, but doesn't work. This configurarion enable the data base monitoring on Java Melody. And I will apply this in our costumer.
This Work in MY SQL
Server.xml
username="xxxxxx"
password="xxxxxx"
url="jdbc:mysql://localhost:3306/jiradb"
maxActive="20"
maxIdle="10"
</Context>
dbconfig.xml
This Doesn't work on Microsoft SQL
Server.xml
username="xxxxx"
password="xxxxx"
url="jdbc:mssql://localhost:1433/jiradb"
maxActive="20"
maxIdle="10"
</Context>
dbconfig.xml
<username>xxxxxx</username>
Best Regards,
Fabio
Fabio Manzoni
This is the message error.
If I remove the java melody information, this instance works very well.
Microsoft SQL - Doesn't Work
My SQL - Working.
Fabio Manzoni
It Works...
I did a mistake and put the mssql-jdbc-6.4.0.jre8 file on Jira. It's wrong!
The dbconfig.xml is correctly and the server.xml I did some adjust, see below.
I hope this information can now help other people...
server.xml
username="xxxxxx"
password="xxxxxx"
maxActive="20"
maxIdle="10"
Like Damien Davis likes this
SMS
March 14, 2018
Hi Fabio!
Thank you for confirming you were able to resolve your issue.
If you'd like, you can put your fix in as a separate Answer (below Suggest an answer) and I can mark it as the accepted answer.
Shannon
Fabio Manzoni
Thank you for your suggestion Shannon. I put  in Suggest an answer.
Administradores January 26, 2022
I have the same problem.
But not for mysql but for postgress
server.xml
<Context path=""
reloadable="false"
useHttpOnly="true">
username="xxxx"
password="xxxx"
driverClassName="org.postgresql.Driver"
url="jdbc:postgresql://xxxxxx"
db.config.xml
<database-type>postgres72</database-type>
<jdbc-datasource>
<url>jdbc:postgresql://xxxxxxxxxx</url>
<driver-class>org.postgresql.Driver</driver-class>
<password>xxxxx</password>
</jdbc-datasource>
<jndi-datasource>
<jndi-name>java:comp/env/jdbc/jirads</jndi-name>
</jndi-datasource>
Any suggestions?
