Java create JIRA problem
liuhze February 24, 2020
Java calls JIRA to create the problem interface. It is found that the handler can only be an administrator and cannot be set as someone else. What is the reason
sukkeong
February 24, 2020
Could you please expand what you are trying to do?
And detail the steps that your program is performing with the resulting error message would be helpful.
liuhze February 25, 2020
The current problem is to use java to call JIRA API to create the problem. The handler can only be set as an administrator, and ordinary users have no permission to display it. The specific code part involves several systems, which is inconvenient to read. The error message cannot be assigned to ordinary users. Please help to analyze it
