Jelly Script to set a Component on an Issue
Justin Taylor May 30, 2013
Hi
I am trying to set a component on an issue using Jelly, I have tried this but it doesnt work:
<core:set var="componentToAdd" value="OPS" />
<core:invoke on="${issueKey}" method="getComponents" var="components" />
<core:invoke on="${components}" method="add" var="flag">
<core:arg type="org.ofbiz.core.entity.GenericValue" value="${componentToAdd}" />
</core:invoke>
<core:invoke on="${issueKey}" method="setComponents">
<core:arg type="java.util.Collection" value="${components}" />
</core:invoke>
But I get the following error:
org.apache.commons.jelly.JellyTagException: null:30:0: Can't convert OPS to class org.ofbiz.core.entity.GenericValue
How would i set a component into the collection in jelly?
Justin Taylor June 10, 2013
After a lot of slogging I got this working well :) see below in bold for this issue!! I have pasted my whole script here in case anyone else has use for it, it covers a lot of jelly questions. Ths script goes through and sets the jira components of an issue based on a custom field component (each issue type has their own component list).
<JiraJelly xmlns:jira="jelly:com.atlassian.jira.jelly.enterprise.JiraTagLib" xmlns:core="jelly:core" xmlns:log="jelly:log">
<!-- This should be copied on to the jira server in <jira-application-dir>/WEB-INF/classes (/opt/atlassian/jira/atlassian-jira/WEB-INF/classes) and in the same location create a jelly-support-component-set.log file -->
<jira:Login username="support.admin" password="$upp0rt">
<!-- The Support No Component filter -->
<core:set var="supportNoComponentFilter" value="13712"/>
<core:set var="componentCommentFail"
value="Support Auto Admin could not automatically associate this issue to a component, the support consultant dealing with this issue will resolve this with the Support Manager."/>
<core:set var="componentCommentSuccess"
value="Support Auto Admin has assigned this issue to component:"/>
<!-- Get an dispatch option for an issue DO_NOT_DISPATCH ISSUE_UPDATED -->
<core:getStatic className="com.atlassian.jira.event.type.EventDispatchOption" field="ISSUE_UPDATED" var="dispatchOption"/>
<!-- Get an instance of ComponentManager -->
<core:invokeStatic className="com.atlassian.jira.ComponentManager" method="getInstance" var="componentManager"/>
<!-- Get an instance of UserManager -->
<core:invokeStatic className="com.atlassian.jira.component.ComponentAccessor" method="getUserManager" var="userManager"/>
<!-- Get a user-->
<core:invoke on="${userManager}" method="getUser" var="user">
<core:arg type="java.lang.String" value="support.admin"/>
</core:invoke>
<!-- Get an instance of IssueManager -->
<core:invoke on="${componentManager}" method="getIssueManager" var="issueManager"/>
<!-- Get an instance of CommentManager -->
<core:invoke on="${componentManager}" method="getCommentManager" var="commentManager"/>
<!-- Get an instance of ProjectComponentManager -->
<core:invoke on="${componentManager}" method="getProjectComponentManager" var="projectComponentManager"/>
<!-- Get an instance of CustomFieldManager -->
<core:invokeStatic className="com.atlassian.jira.component.ComponentAccessor" method="getCustomFieldManager" var="customFieldManager"/>
<!-- Get an instance of sub component field -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="subComponentField">
<core:arg type="java.lang.String" value="customfield_10507"/>
</core:invoke>
<!-- Get an instance of oobaAppComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="oobaAppComponentField">
<core:arg type="java.lang.String" value="customfield_10500"/>
</core:invoke>
<!-- Get an instance of msAppComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="msAppComponentField">
<core:arg type="java.lang.String" value="customfield_10502"/>
</core:invoke>
<!-- Get an instance of networkComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="networkComponentField">
<core:arg type="java.lang.String" value="customfield_10503"/>
</core:invoke>
<!-- Get an instance of hardwareComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="hardwareComponentField">
<core:arg type="java.lang.String" value="customfield_10504"/>
</core:invoke>
<!-- Get an instance of telephonyComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="telephonyComponentField">
<core:arg type="java.lang.String" value="customfield_10505"/>
</core:invoke>
<!-- Get an instance of thirdPartyComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="thirdPartyComponentField">
<core:arg type="java.lang.String" value="customfield_10506"/>
</core:invoke>
<!-- Get an instance of serviceRequestComponentField -->
<core:invoke on="${customFieldManager}" method="getCustomFieldObject" var="serviceRequestComponentField">
<core:arg type="java.lang.String" value="customfield_10800"/>
</core:invoke>
<!-- Run the Support No Component filter -->
<jira:RunSearchRequest filterid="${supportNoComponentFilter}" var="noComponentIssues"/>
<!-- Loop through the filter results -->
<core:forEach var="noComponentIssue" items="${noComponentIssues}">
<!-- Get an instance of IssueObject -->
<core:invoke on="${issueManager}" method="getIssueObject" var="issueKey">
<core:arg type="java.lang.String" value="${noComponentIssue.key}"/>
</core:invoke>
<core:catch var="JellyTagException">
<!-- Get an instance of oobaAppComponentFieldValue -->
<core:invoke on="${oobaAppComponentField}" method="getValue" var="oobaAppComponentFieldValue">
<core:arg type="com.atlassian.jira.issue.IssueImpl" value="${issueKey}"/>
</core:invoke>
<core:set var="incidentComponentValue" value="${oobaAppComponentFieldValue}"/>
</core:catch>
<core:if test="${incidentComponentValue == null}">
<!-- Get an instance of msAppComponentFieldValue -->
<core:invoke on="${msAppComponentField}" method="getValue" var="msAppComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${msAppComponentFieldValue}"/>
</core:catch>
</core:if>
<!-- Get an instance of networkComponentFieldValue -->
<core:invoke on="${networkComponentField}" method="getValue" var="networkComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${networkComponentFieldValue}"/>
</core:catch>
</core:if>
<!-- Get an instance of hardwareComponentFieldValue -->
<core:invoke on="${hardwareComponentField}" method="getValue" var="hardwareComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${hardwareComponentFieldValue}"/>
</core:catch>
</core:if>
<!-- Get an instance of telephonyComponentFieldValue -->
<core:invoke on="${telephonyComponentField}" method="getValue" var="telephonyComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${telephonyComponentFieldValue}"/>
</core:catch>
</core:if>
<!-- Get an instance of thirdPartyComponentFieldValue -->
<core:invoke on="${thirdPartyComponentField}" method="getValue" var="thirdPartyComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${thirdPartyComponentFieldValue}"/>
</core:catch>
</core:if>
<!-- Get an instance of serviceRequestComponentFieldValue -->
<core:invoke on="${serviceRequestComponentField}" method="getValue" var="serviceRequestComponentFieldValue">
</core:invoke>
<core:set var="incidentComponentValue" value="${serviceRequestComponentFieldValue}"/>
</core:catch>
</core:if>
<core:choose>
<core:when test="${incidentComponentValue.toString().indexOf(',') > -1}">
<!-- Get the component to set from the incident component -->
<core:set var="equalIndex" value="${incidentComponentValue.toString().indexOf('=')}"/>
<core:set var="commaIndex" value="${incidentComponentValue.toString().indexOf(',')}"/>
<core:set var="oComponentToAdd" value="${incidentComponentValue.toString().substring(equalIndex+1,commaIndex+0)}"/>
<core:set var="componentToAdd" value="${oComponentToAdd.toString().trim()}"/>
</core:catch>
<!-- Get the sub - component to set from the incident component -->
<core:set var="subCompLastEqualIndex" value="${incidentComponentValue.toString().lastIndexOf('=')}"/>
<core:set var="subCompBracketIndex" value="${incidentComponentValue.toString().indexOf('}')}"/>
<core:set var="oSubComponentToAdd" value="${incidentComponentValue.toString().substring(subCompLastEqualIndex+1,subCompBracketIndex+0)}"/>
<core:set var="subComponentToAdd" value="${oSubComponentToAdd.toString().trim()}"/>
</core:catch>
</core:when>
<core:otherwise>
<!-- No sub-component set so just extract incident component and code sub-component to None-->
<core:set var="bracketIndex" value="${incidentComponentValue.toString().indexOf('}')}"/>
<core:set var="oComponentToAdd" value="${incidentComponentValue.toString().substring(equalIndex+1,bracketIndex+0)}"/>
</core:catch>
<core:set var="subComponentToAdd" value="None"/>
</core:otherwise>
</core:choose>
<core:choose>
<core:when test="${componentToAdd != null}">
<!-- Get the projectComponent to update the issue with from the projectComponentManager -->
<core:invoke on="${projectComponentManager}" method="findByComponentName" var="projectComponent">
<core:arg type="java.lang.Long" value="${issueKey.project.id}"/>
<core:arg type="java.lang.String" value="${componentToAdd}"/>
</core:invoke>
<!-- Get the components list of the issue to update -->
<core:invoke on="${issueKey}" method="getComponentObjects" var="components"/>
<!-- Add the project component to the list -->
<core:arg type="com.atlassian.jira.bc.project.component.ProjectComponent" value="${projectComponent}"/>
</core:invoke>
<!-- Set the components list back on to the issue -->
<core:invoke on="${issueKey}" method="setComponentObjects">
<core:arg type="java.util.Collection" value="${components}"/>
</core:invoke>
<core:if test="${subComponentToAdd != null}">
<!-- Update the sub component field -->
<core:invoke on="${issueKey}" method="setCustomFieldValue">
<core:arg type="com.atlassian.jira.issue.fields.CustomField" value="${subComponentField}"/>
<core:arg type="java.lang.Object" value="${subComponentToAdd}"/>
</core:invoke>
</core:if>
<!-- Update and re index the issue -->
<core:invoke on="${issueManager}" method="updateIssue" var="updatedIssue">
<core:arg type="com.atlassian.crowd.embedded.api.User" value="${user}"/>
<core:arg type="com.atlassian.jira.issue.MutableIssue" value="${issueKey}"/>
<core:arg type="com.atlassian.jira.event.type.EventDispatchOption" value="${dispatchOption}"/>
<core:arg type="boolean" value="false"/>
</core:invoke>
<core:invoke on="${commentManager}" method="create" var="comment">
<core:arg type="java.lang.String" value="${componentCommentSuccess} ${componentToAdd}"/>
</core:invoke>
</core:when>
<core:otherwise>
<core:invoke on="${commentManager}" method="getCommentsForUser" var="comments">
</core:invoke>
<core:set var="commentedAlready" value="false"/>
<core:forEach var="comment" items="${comments}">
<core:if test="${comment.getBody().equalsIgnoreCase(componentCommentFail)}">
<core:set var="commentedAlready" value="true"/>
</core:if>
</core:forEach>
<core:if test="${commentedAlready.toString().equalsIgnoreCase('false')}">
<core:arg type="java.lang.String" value="${componentCommentFail}"/>
</core:invoke>
</core:if>
</core:otherwise>
</core:choose>
</core:forEach>
</jira:Login>
</JiraJelly>
Darren Pegg
October 8, 2013
Thanks Justin
Tsol
June 3, 2013
You could use jira:TransitionWorkflow tag. Create a transition that returns to itself and during the transition you could update the issue component.
Zul NS _Atlassian_
June 3, 2013
May I suggest using REST API instead? You can check out the PUT method using /rest/api/2/issue/
Ok i have just tried using string and it works up to a point, it now populates the component collection, but its not setting the component on the issue:
<core:arg type="java.lang.String" value="OPS" />
</core:invoke>
<jira:AddComment comment="components ${components}" issue-key="SUP-27096"/>
</core:invoke>
thank you in advance :)
