Jira 6.1.3 Plugins Won't Load
Terry Johnson November 16, 2013
I have installed Jira 6.1.3 on Windows 2008 r2 (VM) server as a service. Each time I try to access the Jira dashboad, the plugins won't load (according to the log) - sometimes 13, sometimes 31, sometimes 50, etc. I have tried everything recommended on your website to resolve this issue but have had no success. Can you recommend the correct specs for a VM server running Windows 2008 r2, SQL Server 2012 and Jira 6.1.3?
Marcus Silveira
November 17, 2013
If these are system plugins not starting during JIRA startup, it may be related to this KB article
https://confluence.atlassian.com/display/JIRAKB/JIRA+System+Plugin+Timeout+While+Waiting+for+Plugins+to+Enable
You can try increasing the timeout value for the plugins (-Datlassian.plugins.enable.wait=300) but this is mainly caused by the server not having enough resources for a good performance. Maybe you need to allocate more resources to the VM.
Hope this helps
Terry Johnson November 23, 2013
Increasing the memory to the VM resolved the issue. Thanks!
Increasing the memory to the VM solved the problem. Thanks!
Norman Abramovitz
November 16, 2013
It is hard to say what your issue is without some logs being posted. My best guess would be memory, but without seeing the actual errors and what you actually tried already it is difficult to know what to tell you what to try next.
