Hello All,
Please help me, we've just upgraded from Jira 7 to Jira 8.
1 of our scripts failed. ComponentManager no longer usable. Could you help me how can I revive the script?
ChangeHistoryManager changeHistoryManager = (ChangeHistoryManager)ComponentManager.getComponentInstanceOfType(ChangeHistoryManager.class);
The error message: [Static type checking] - The variable [ComponentManager] is undeclared.
Thank you!
The full script
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.changehistory.ChangeHistory;
import com.atlassian.jira.issue.changehistory.ChangeHistoryManager;
import com.atlassian.jira.issue.status.Status;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import org.ofbiz.core.entity.GenericValue;
Logger log = LoggerFactory.getLogger("Previous Status Field");
log.debug("Issue " + issue.getKey());
List changeHistory = changeHistoryManager.getChangeHistories(issue);
for (int i = changeHistory.size() - 1; i >= 0; i--)
ChangeHistory changeHistoryItem = (ChangeHistory)changeHistory.get(i);
List changeItemBeans = changeHistoryItem.getChangeItems();
Iterator it = changeItemBeans.iterator();
while (it.hasNext())
GenericValue change = (GenericValue)it.next();
String changedField = change.getString("field");
if (changedField.equalsIgnoreCase("status"))
String oldStatus = change.getString("oldstring");
return oldStatus;
return null;
Some Details to above:
ComponentManager has been deprecated since JIRA 7.11, which is the reason that you cannot resolve this class any longer.
You should migrate to using ComponentAccessor instead-> https://docs.atlassian.com/software/jira/docs/api/7.11.0/com/atlassian/jira/component/ComponentAccessor.html
getComponent and getComponentByType are two key methods to load components of a specific type. Sample code is below:
Old Code:
RemoteIssueLinkService remoteIssueLinkService = ComponentManager.getComponentInstanceOfType(RemoteIssueLinkService.class)
RemoteIssueLinkService.RemoteIssueLinkListResult links = remoteIssueLinkService.getRemoteIssueLinksForIssue(currentUser, issue)
New Code:
ComponentAccessor.getComponentOfType(RemoteIssueLinkService.class).getRemoteIssueLinksForIssue(currentUser, issue);
use ComponentAccessor instead
