Jira API: Issue create post to respond with Issue status information
jeremiah kiplagat
February 15, 2019
When creating an Issue in Jira via REST API, the response is as such:
"id":"10595",
"key":"XXX-591",
"self":"https://xxx.atlassian.net/rest/api/2/issue/10595"
 Is it possible to get Jira to respond with more info? Something like:
"id":"10595",
"key":"XXX-591",
"self":"https://xxx.atlassian.net/rest/api/2/issue/10595",
"status": "Open"
 Appreciate your help :-)
Matthias Gaiser _K15t_
Hi @jeremiah kiplagat,
this is unfortunately not possible, but you can call get issue afterwards and define in the fields parameter all fields you want to have returned.
Matthias.
jeremiah kiplagat
February 15, 2019
Hi @Matthias Gaiser _K15t_ ,
Thanks for the quick response.
That's actually what I ended up doing, just wanted to see if that could be improved. Anyway, thanks for the answer.
Best regards
