Jira API - Need results of current year issues
Syed Arif December 16, 2022
Jira API - Need results of current year issues - Am using the below API's in Power query to get the results of current year 2022 - but i also see it's giving me previous year isues.
Can some1 pls help
https://XXXX.com/jira/rest/api/2/search?jql=project in (xxx,xxx,xxx)&maxResults=2000&AND created >= startOfYear()
https://XXXX.com/jira/rest/api/2/search?jql=project in (xxx,xxx,xxx)&maxResults=2000&createdDate>=\"2022/01/01\" and createdDate<=\"2022/12/31\"'";
Renzo Arriagada
December 16, 2022
Hi @Syed Arif !
You have written wrongly your API calls
They should look like this:
Although I'm not sure if you're going to be able of setting the maxResults to 2000 due to limitations on the app itself to restrict expensive API calls that might disrupt the service.
The important thing to note on both calls is that you first must build your jql as one parameter and then you can add more parameters to the call using &
I hope this helps.
Renzo from Servicerocket.
Syed Arif December 17, 2022
Yes, This helps :) Thank you :)
Syed Arif December 21, 2022
can you pls help me with search API request header
and
exclude columns which has Null values ?
