×How can I get this query to work for my team? Comment!~ "success couponscom-integration"
I trying to display only tickets that do not have the comment 'success couponscom-integration'
Using Comment ~ seems to work just fine but the Comment!~ does not appear to catch it all. I'd like to use this on my rapidboard to see which stories and bugs have not been merged to integration or release.
Hi Steve,
If you search by comment, the JQL query will only search for those issues which have been commented on, which means that all the issues without comments will be ignored.
And please note that the query comment !~ 'success couponscom-integration' is not a negation of comment ~ 'success couponscom-integration'. For example, if an issue has 2 comments, 1 with the phrase 'success couponscom-integration' and 1 without, both of the above queries will include this issue in the search result, because:
My suggestion in this case is to try installing JIRA Toolkit plugin. It provides several custom fields that may help you extend your JQL. These potentially useful custom fields include:
All the best,
Andy
You are correct Andy, so a solution would be to create a filter that shows issue which contains "success couponscom-integration" and then simply negate that filter
Filter1 is: comment ~ "\"success couponscom-integration\""
and then use
not filter = filter1
Hi Udo,
Have you tested this on your side? I'm afraid this will cause a cyclical reference error owing to the nature of comment field to search for all comments in every issue (as I mentioned earlier ~ cannot negate !~). For more information, kindly have a look at this: Non-consistent cyclical reference handling in JQL.
Andy
Hi Andy,
yes, it is working.
Cheers, Udo
Have you tried
comment !~ "\success couponscom-integration\""
Since you are searching for a phrase see also https://confluence.atlassian.com/display/JIRA/Advanced+Searching#AdvancedSearching-Comments
thanks all for the replies. I'll try these and see what we get.
