import java.text.SimpleDateFormat
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.event.type.EventDispatchOption
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import java.time.LocalDate
import java.time.format.DateTimeFormatter
def versionManager = ComponentAccessor.getVersionManager()
def issue = event.issue
def project = issue.getProjectObject()
def projectKey = "test"
// Check if the project key matches "test"
if (project.key == projectKey) {
// Get the Fix Version field value from the issue
def fixVersions = issue.getFixVersions()
def projectID = issue.getProjectId()
// Check if its a feature and it has a fix version
if (issue.issueType == 'Feature' && fixVersions != null) {
// Get all releases in the "test" project
def testReleases = versionManager.getVersionsUnreleased(project.getId(), false)
// Loop through the Fix Versions of the issue
for (def fixVersion in fixVersions) {
if(testReleases.find { it.id == fixVersion.id}){
def releaseStartDate = fixVersion.startDate
def releaseEndDate = fixVersion.releaseDate
log.warn("start date: " + releaseStartDate)
log.warn("end date: " + releaseEndDate)
// Format the dates as strings with the format "dd-MMM-yyyy"
def dateFormat = new SimpleDateFormat("dd-MMM-yyyy") as String
def formattedStartDate = releaseStartDate.format(dateFormat)
def formattedEndDate = releaseEndDate.format(dateFormat)
// Set the custom field values
def targetStart = customFieldManager.getCustomFieldObjectsByName("Target start")
def targetEnd = customFieldManager.getCustomFieldObjectsByName("Target end")
// Start a new transaction to make the changes
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
MutableIssue featureIssue = issue as MutableIssue
//error comes here, the method will not recognize the formatted date
targetStart.updateValue(null, featureIssue, new ModifiedValue(featureIssue.getCustomFieldValue(targetStart), formattedStartDate), new DefaultIssueChangeHolder())
targetEnd.updateValue(null, featureIssue, new ModifiedValue(featureIssue.getCustomFieldValue(targetEnd), formattedEndDate), new DefaultIssueChangeHolder())
//also tried the setCustomFieldValue method, but no luck
//featureIssue.setCustomFieldValue(targetStart, releaseStartDate)
//featureIssue.setCustomFieldValue(targetEnd, releaseEndDate)
issueManager.updateIssue(currentUser, featureIssue, EventDispatchOption.DO_NOT_DISPATCH, false)
break
Is it because the Target start and Target end dates are locked fields from Advanced Roadmaps that they can't be edited via Scriptrunner?
