Greetings!
I'm trying to edit a specific comment containing a string that only happens if the comment exists - that condition is working.
But when I try to get the right comment id with the following smart values, it does not work in the field for the id, but when I use it in a comment.
{{#comments}}
{{#body.endsWith("String")}}
{{first.id}}
{{/}}Does anyone has an idea why it does not work and how to make it work?
Hi, this works for me:
{{#issue.comments}}{{#if(exists(body.match(".*(YOUR TEXT).*")))}}{{id}}{{/}}{{/}}
This will retrieve the id of the comment which has YOUR TEXT
