×i want to get notified via slack whenever a story changed its stauts to "done"
can this be achieved with Jira automation ?
Yes, you can do this with automation and in its simplicity the automation would look something like this:
Hi @Ilan Goldschmidt ,
Welcome to the community!
Please find the details below
You may even use the send email feature
your-label
example@example.com or add a group or any user field
Issue {{issue.key}} Status Changed
The status of issue {{issue.key}} ({{issue.summary}}) has changed
Thank You,
Prachi
