Jira Automation - Issue creating subtasks
Michelle Nunes April 2, 2024
I have set up a rule to create daily issues (Story) and then added a component to the rule to create sub tasks to issue, once it is created
But when this executes, i get the following error.
with no details about the error.
Also, the main story gets created, but the sub-tasks are not created
Please could you help
2 accepted
Ste Wright
Hi @Michelle Nunes
You need to use a Branch to create Sub-tasks, and link them back to the Story created earlier in the rule.
For example...
  • Trigger: Scheduled
  • Action: Create issue
    • Project = DBA Task Tracking
    • Issue type = Story
  • Branch: Related issues
    • Type = Most recently created issue
      • Branch-Action: Create issue
        • Issue type = Sub-task
        • Parent issue = Current issue
      • ...etc
Let us know how it goes :)
Ste
Michelle Nunes April 7, 2024
Thanks Stephen, this worked!
Like Ste Wright likes this
Asha Goyal
April 2, 2024
Hello @Michelle Nunes
Welcome to the Atlasssian Community !
For creating a subtask under  a task you need to make a use of condition and branch in the automtion. See the usage of conditional branching and then create subtask under it. Here is the screen shot attached for your further reference.
KIndly Accept and Vote if it helps.
Thanks AG, this is similar to the first reply and it worked!
Like Asha Goyal likes this
