I'm working on creating a default project template for my team with automation, which focuses on automatically creating default Epics/Stories and Tasks when a new project is created.
When I try to add a trigger? I'm unable to find triggers like "when a new project is created" or "manual Trigger", etc.
Hi @Sameeksha Santhosh Naik and welcome to Community!
The "Project created" trigger is only available in the Global automation menu (System > Automation > Global automation). If you don't see that trigger, you're most likely looking at the project-level automation menu instead of the global one.
Here's the Project created trigger in the Global automation menu:
Hope this helps!
- Manon
Hello @Sameeksha Santhosh Naik ☺️, If you're open to using a third-party app for your cloud instance, I think Templating.app could be a good option for your use case as well.
You can find us at the Atlassian Marketplace ➡️ https://marketplace.atlassian.com/apps/1224664
Or check out a quick video guide on how this works:
https://www.youtube.com/watch?v=xYiVFJLziNU&list=PLs3DY-Wn823FbkGsazjeV0F5O1jUMk2wG&index=10
Welcome to the Community !
Automation trigger, specially Project create isn't related to plan of instance; something might be a issue/glitch.Can you check in automation template and try it or import such to test?EDIT: Project creation trigger is in global automation only, not from automation section of the project.
