×Hello,
I am working on Jira automation to send Slack notifications to the private channel when certain criteria is met for a Jira ticket. But I am getting the below error:
Hi @Amit Jash
I recall a similar question last week for the Atlassian-provided Slack integration and the conclusions were:
Hi @Amit Jash ,
Are you using a native Slack <> Jira integration or something else? Can you share some additional information such as screenshots of the configuration?
I believe Teams do have this limitation (where you cannot connect private channels via this type of integration), but I know we've used this integration in Slack private channels > meaning, it was definitely possible.
Tobi
HI @Tomislav Tobijas ,
Yes I believe we are using native Slack <> Jira integration.
Screenshot of automation:
Error:
be-team channel:
@Amit Jash I've just tested this (with the latest Slack version 4.42.120 (beta; Windows), not that environment should matter) and integration seems to be working fine. For example, I have implemented a similar thing, just without specifying the channel in Channel or user field > as it is defined within the webhook.
Can you maybe try to regenerate a Slack webhook and see if notifications are still not being sent?
Note that I'm using legacy webhook integration. Not sure which one you've been using so far.
