Hi everyone,
I'm trying to create an automation rule in Jira that automatically clones any newly created "Bug" issue to another project (called QA Bug
Here's what I've done so far:
Trigger: Issue Created
Log Action: ISSUE TYPE - {{issue.issueType.name}}
→ This correctly logs Bug
Condition:
Field: Issue Type
Condition: equals
Value: Bug
Action: Clone the issue to QA Bug
project
However, the rule fails at the condition, and the audit log says: The following issues did not match the condition:
The log clearly shows: ISSUE TYPE - Bug
I’ve also tried:
Changing the condition to is not one of
Using is one of
instead of equals
Still no luck.
Hi @Moshood -- Welcome to the Atlassian Community!
There are at least two causes of that symptom:
1) The Issue Created trigger can fire so quickly that some data may not be stable / available when the rule starts. The fix for this is to always add the Re-fetch Issue action immediately after that trigger. This will slow the rule a bit, and reload the data before proceeding.
2) What is the scope of your rule, in the details at the top: single-project, multiple-project, or global?
When a rule is multiple-project or global and there are team-managed projects impacted, the different issue types could have the same names but different type ID values, causing conditions and rule actions to fail.
The solution is to specifically test the issue type by name, or by the ID for narrower cases. For example, rather than using the Field Values condition use the Smart Values condition:
Hi Bill,
Thanks a lot for the warm welcome and the detailed explanation!
Using the Smart Values condition to check {{issue.issuetype.name}} did the trick. Once I switched to that approach, the rule started working as expected.
Truly appreciate your help!
Moshood
