Jira Automation Rule
Vinay Kumar Murjiani
August 21, 2024
I’m setting up a new rule in Jira automation to trigger when a new issue of type "Story" is created and then edit the "description" field. This rule should apply only to newly created stories, and I want to ensure that the description field is not edited when cloning existing tickets.
My current rule:
When issue created - Trigger
Issue type equals story - If condition
Then edit the issue field (description)
I know I have to add to add another If condition to ensure that when the issue is cloned, do not edit the description field in that cloned story. Can you help me to figure out how I can do that?
Trudy Claspill
Hello @Vinay Kumar Murjiani
The only way to know that an issue might have been created using the Clone process is if the new issue has a "clones" link to the original issue. Since links can be added and removed by users, there is no guarantee that an issue created by Cloning will have that link, nor that an issue that has such a link was actually created using a Clone process.
If you want to add a condition like that you could use the Related Issues condition:
August 22, 2024
Thank you
Trudy Claspill
You're welcome.
If my response has helped you solve your requirement please consider click the Accept Answer button to mark your post as Solved.
GAY LEE HOLLON September 3, 2024
If you want to keep old description and add new verbiage, this is what we use
