Jira Automation: check for status change if issue has a certain status before.
Stefan Siegel
December 8, 2022
I am a newbie when it comes to Jira automation rules. Therefore my question:
is it possible to create an automation rule which executes a command (seeting a field value) only when an issue changes from status A to status C but not when the transition is from B to C ?
Thanks for a hint.
John Driscoll
Try this option within the Automation configuration screen.
Using the drop-down lists, you can select both the SOURCE status and DESTINATION status values.
Stefan Siegel
December 8, 2022
Thanks John, that helped!
Like # people like this
