Jira Automation fail
arno
Hi
I'm having some problems using Automation Lite for Jira
The effect I want to achieve is to periodically detect the jira issue and switch a particular issue to a specified state, as shown in the attachment
Currently, the Do and Working issue has been successfully switched to Suspend state, but the INITALL issue has not been switched successfully. Is there a problem with the rule I setrule.png
arno
In addition, whether it is related to the work flow, the work flow I set is as followsworkflow.png
Kristopher Perez
February 13, 2023
Thanks for sharing the Workflow. The answer actually lies in there. There is no path from INITALL to SUSPENDED.
The Automation works exactly right. You just need to update the Workflow to provide a transition.
Kris
Like # people like this
Sabeena
