I've created a jira automation that creates a table in the description field based on custom fields I added to the form, and I'm also calculating the sum of all items i.e if I have an order for 10 devices it will calculate each device type unit * price per table row and in the bottom of the table will post the total of all devices:
Here is the automation rule:
||*Needed Device*||*Quantity*||*Cost Summary*|| |{{issue.Needed Mobile Device New}}|
{{issue.Quantity New}}|{{#=}}{{issue.Needed Mobile Device New.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New}}{{/}}| |
{{issue.Needed Mobile Device New 2}}|{{issue.Quantity New 2}}|{{#=}}{{issue.Needed Mobile Device New 2.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 2}}{{/}}|
|{{issue.Needed Mobile Device New 3}}|{{issue.Quantity New 3}}|{{#=}}{{issue.Needed Mobile Device New 3.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 3}}{{/}}|
|{{issue.Needed Mobile Device New 4}}|{{issue.Quantity New 4}}|{{#=}}{{issue.Needed Mobile Device New 4.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 4}}{{/}}|
|{{issue.Needed Mobile Device New 5}}|{{issue.Quantity New 5}}|{{#=}}{{issue.Needed Mobile Device New 5.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 5}}{{/}}|
|{{issue.Needed Mobile Device New 6}}|{{issue.Quantity New 6}}|{{#=}}{{issue.Needed Mobile Device New 6.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 6}}{{/}}|
|{{issue.Needed Mobile Device New 7}}|{{issue.Quantity New 7}}|{{#=}}{{issue.Needed Mobile Device New 7.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 7}}{{/}}|
|{{issue.Needed Mobile Device New 8}}|{{issue.Quantity New 8}}|{{#=}}{{issue.Needed Mobile Device New 8.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 8}}{{/}}|
|{{issue.Needed Mobile Device New 9}}|{{issue.Quantity New 9}}|{{#=}}{{issue.Needed Mobile Device New 9.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 9}}{{/}}|
|{{issue.Needed Mobile Device New 10}}|{{issue.Quantity New 10}}|{{#=}}{{issue.Needed Mobile Device New 10.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 10}}{{/}}|
Total = ${{#=}}({{issue.Needed Mobile Device New 2.getValue().substringAfter("$")}} * {{issue.Quantity New 2}}) + ({{issue.Needed Mobile Device New 2.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 2}}) + ({{issue.Needed Mobile Device New 3.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 3}}) + ({{issue.Needed Mobile Device New 4.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 4}}) + ({{issue.Needed Mobile Device New 5.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 5}}) + ({{issue.Needed Mobile Device New 6.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 6}}) + ({{issue.Needed Mobile Device New 7.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 7}}) + ({{issue.Needed Mobile Device New 8.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 8}}) + ({{issue.Needed Mobile Device New 9.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 9}}) + ({{issue.Needed Mobile Device New 10.getValue().substringAfter("$").remove(",")}} * {{issue.Quantity New 10}}){{/}}
Problem is that this handles full 10 fields per each device, so if for example I'm only ordering one or two devices I get an error for the '*' operand that the automation can't resolve it, any suggestions on how to solve it without creating massive if blocks per each situation?
Hi @Ron Aisen
What do you want to do when a quantity value is 0 or empty:
I am unclear how to mix those options as they seem mutually exclusive...
To prevent display of a row with a 0 quantity, wrap each row with a conditional, smart value expression to test for a 0 or empty quantity: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/
To display all rows, with 0 when relevant, use either 0 prefix value or default value, as @Manon Soubies-Camy described. Please note well: that syntax does not work for all possible field types, and I recommend testing to confirm for your fields.
Hi @Ron Aisen,
You can use | to provide automation rules with default values if your field is empty, for example:
{{#=}}{{issue.story points|1}} * 5{{/}}
If the Story points field is empty, then it'll be replaced with value 1.
Hope this helps!
- Manon
Thanks Manon, it didn't answer my need but I appreciate the help
I ended up doing if blocks saddly but it works so that's what counts
