Jira Automation rule
Eswar Tucha May 30, 2023
We have below requirement:
Sum of 2 number fields(field1 & field2) in subtask should be updated in parent task field (Field3).
Example:
Field3(parent) should only get updated when sum of field1(subtask) and field2(subtask) is greater then field3(parent).
Example with field values:
Field3: 10
Field1: 7
Field2: 7
In this case, sum of 2 subtask field values (14) is greater then Field3(parent), then it field in the parent issue should update.
If sum of 2 subtask field values is lesser than Parent issue field value, then the parent issue field should not get updated.
Automation rule written:
Trudy Claspill
Hello @Eswar Tucha
Does your scenario consider that the parent issue may have multiple subtasks? It seems like you are describing a scenario where the parent issue could be updated repeatedly for changes based on a single subtask when it may have multiple subtasks.
Would it not make more sense to sum the effort information of all the subtasks to see if that is greater than the effort estimated for the parent task?
Also, I see from the rule that you have shared that the fields you are looking at are Actual Dev Effort and Planned Dev Effort. If you add those two fields together you are getting more "effort" time than is either planned or actually expended. Why would you want to add Planned and Actual together?
Hello @Trudy Claspill
Yes, parent issue will have multiple subtasks. Effort on parent task should only get updated if sum of 2 effort fields in subtask is greater than effort on parent task.
Why would you want to add Planned and Actual together? - These are sample fields that we are using in sandbox, field names would change later.
Let us consider Planned and Actual are subtask fields and Code review is Parent task field with not much bothering about names of the fields.
Also, these number fields should not take negative values.
Please help
Trudy Claspill
There is more than one way to achieve your requirement. This is how I would do it.
TRIGGER: When field value changes (specifying the fields in your subtask)
CONDITION: Issue type = subtask
BRANCH: For Parent
CONDITION: Advanced Compare
First Value: {{triggerIssue.<custom field 1>.plus(triggerIssue.<custom field 2>)}}
Operator: is greater than
Second value: {{issue.<custom field 3>}}
THEN ACTION: Edit issue
Field: custom field 3
Sanjog Sigdel
Hi @Eswar Tucha
I don't have the answer for this question. But my curiosiry is on the change request here. Can you please share the Use Case of such requirement and what you want to achieve out of this?
I've so far been able to implement the following:
  1. Updating the sum of Total Story Points under an EPIC,
  2. Total Story Points completed in an EPIC
  3. Total Story Points Remaining under an EPIC.
You can find how I did it in this question:
Error-while-using-lookupIssues-JIra-Smart-Value-to-sum-story
This helps me to view the Progress on EPIC. But that is the use case of Subtasks less than greater than and sum in some if case.
Hi @Sanjog Sigdel
Our goal is to calculate the efforts wherein different users work on child issues and updates their efforts.
Hence, sum of efforts in subtask should update in parent issue only if the efforts are greater than parent issue, so that we can plan the effort for issue accordingly.
Like Sanjog Sigdel likes this
Sanjog Sigdel
Oh I see @Eswar Tucha. Will your automation capture the following scenario?
"I estimated a ticket would take 5 hours to complete. Then the team members logged their hours in their respective sub-tasks. It happen to be a total of 4.5hrs."
Shouldn't we capture that and update the original estimate? Or log the total effort it took to complete a ticket?
