I want to setup a certificate reminder using Jira Task which is in 2 years time? How can I setup a task using Jira Automation?
You could also schedule it using a CRON expression. I use this site for help with my CRON expressions
Thanks Jeff, not sure how can I setup up the cron job for more than 12 months.
Hi @Ranjan Koirala -
It looks like Automation allows for scheduling a rule execution for these times:
So depending on precision, maybe one of those will work?
Thanks Darryl, when I tried the scheduled trigger it says the interval should greater than 5 mins and less than a year. Can you please send the screen short/syntax how I can schedule for more than 12 months.
