Have implemented the new Jira native automation feature on our next gen project using the template rule "Close epic when all stories have been completed". However when creating a text epic with tasks and following the automation rules nothing changes on the epic status.
Can see when going to the automation dashboard that it says that is successfully completed the action but nothing has changed on the parent task, even after refreshing.
Hi @Henry Hill Can I see what is your condition for this rule. Cause I though you said that if all story completed then transit their parent (epic) to closed. But you have task ( not story) here. And why don’t you do this rule by workflow?
