Jira Bamboo Plugin will not "Enable" for Bamboo v4.3.3 or v5.0.1
Gesner Herard, Jr. August 19, 2013
Jira Bamboo Plugin stopped working after updating Jira to v6.0.6. Was at Bamboo v4.3.3. Updated Bamboo to v5.0.1 and still get the same problem. Log file shows the following (note: the how-to page listed "http://confluence.atlassian.com/x/1xy6D" does not exist):
=== atlassian-bamboo.log Pre-Bamboo v5.0.1 install ========
2013-08-16 00:26:16,653 ERROR [WrapperSimpleAppMain] [OsgiPlugin] Detected an error (BundleException) enabling the plugin 'com.atlassian.jira.plugin.ext.bamboo' : Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [55]: Unable to resolve 55.0: missing requirement [55.0] osgi.wiring.package; (&(osgi.wiring.package=com.atlassian.jira)(version>=5.0.0)). This error usually occurs when your plugin imports a package from another bundle with a specific version constraint and either the bundle providing that package doesn't meet those version constraints, or there is no bundle available that provides the specified package. For more details on how to fix this, see http://confluence.atlassian.com/x/1xy6D
=== atlassian-bamboo.log Post-Bamboo v5.0.1 install ========
2013-08-20 10:00:02,296 ERROR [WrapperSimpleAppMain] [OsgiPlugin] Detected an error (BundleException) enabling the plugin 'com.atlassian.jira.plugin.ext.bamboo' : Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [62]: Unable to resolve 62.0: missing requirement [62.0] package; (&(package=com.atlassian.jira)(version>=6.0.0)). This error usually occurs when your plugin imports a package from another bundle with a specific version constraint and either the bundle providing that package doesn't meet those version constraints, or there is no bundle available that provides the specified package. For more details on how to fix this, see http://confluence.atlassian.com/x/1xy6D
2013-08-20
10:00:02,298 WARN [WrapperSimpleAppMain] [OsgiPlugin] Unable to enable plugin 'com.atlassian.jira.plugin.ext.bamboo'
com.atlassian.plugin.osgi.container.OsgiContainerException: Cannot start plugin: com.atlassian.jira.plugin.ext.bamboo
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:445)
at com.atlassian.plugin.impl.AbstractPlugin.enable(AbstractPlugin.java:237)
at com.atlassian.plugin.manager.PluginEnabler.actualEnable(PluginEnabler.java:114)
at com.atlassian.plugin.manager.PluginEnabler.enable(PluginEnabler.java:99)
at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:725)
at com.atlassian.plugin.manager.DefaultPluginManager.init(DefaultPluginManager.java:178)
at com.atlassian.bamboo.container.BambooContainer.init(BambooContainer.java:182)
at com.atlassian.bamboo.container.BambooContainer.initialise(BambooContainer.java:147)
at com.atlassian.bamboo.upgrade.UpgradeLauncher.initialiseBambooContainer(UpgradeLauncher.java:190)
at com.atlassian.bamboo.upgrade.UpgradeLauncher.upgradeAndStartBamboo(UpgradeLauncher.java:93)
at com.atlassian.bamboo.upgrade.UpgradeLauncher.contextInitialized(UpgradeLauncher.java:40)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:733)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:233)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1222)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:676)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:455)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:90)
at org.eclipse.jetty.server.Server.doStart(Server.java:261)
at com.atlassian.bamboo.server.Server.main(Server.java:74)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:240)
at java.lang.Thread.run(Unknown Source)
Caused by: org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [62]: Unable to resolve 62.0: missing requirement [62.0] package; (&(package=com.atlassian.jira)(version>=6.0.0))
at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3409)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1709)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:905)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:892)
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:417)
... 26 more
Gesner Herard, Jr. August 21, 2013
This is with the latest version of the Jira Bamboo plugin installed:
Version: 6.1.7
Developer:Atlassian Software Systems Pty Ltd
Add-on key: com.atlassian.jira.plugin.ext.bamboo
Note also, that the listing under "User-installed Add-ons" is grey out as well (probobly indicating that it is disabled).
Yilin
August 20, 2013
Maybe you should try the lastest version of Bamboo plugin
https://marketplace.atlassian.com/plugins/com.atlassian.jira.plugin.ext.bamboo
As it had been recently compatible with JIRA 6.
Version: 6.1.7
Gesner Herard, Jr. August 26, 2013
As mentioned in my reply to the last comment, I have used the lastest version of Bamboo plugin and still have the same error. The issue is still NOT resolved.
