Hello everyone,
I have activated the native integration between Jira and Bitbucket and am running into a minor issue: Bitbucket builds aren't showing on the associated Jira ticket.
Here's my steps to reproduce:
What I see in my ticket: Commit messages, the pull request, and the deployment. However, the build section is blank.
Does anyone know how to fix this?
Update: The issue appears only to occur when you are merging branches. If your YAML file triggers a build on-commit to your branch, that is tracked in Jira. However, if you open a pull request that will merge to a branch (which also triggers a build on-commit) then the Jira ticket will show the Deployment, but fails to attach the build to the ticket - despite the build metadata having your branch name stickered all over it.
This seems like an oversight in the out-of-the-box integration.
Hey All, Any advise on how to resolve this? Having the same issue
Are there any plans to address this issue? It's still occurring.
