Hi, Is there a way to automatically create the Bugs in Jira? i works as a CPU verification Engineer in VLSI domain. I use Jira at my work to reports in CPU. Can i know how to automate the bug filing process. Is there a template for this. Please let me know.
There is a way to automate the bug creation using the "Automation" rules in Jira.
To help you I would need some extra information like :
You can learn also more about it by having a look at the following video by the creators of automation on Jira : https://www.youtube.com/watch?v=r15tWhl5XjM
Keep me informed !
Thanks for your quick reply Guilhem Dupuy. I works for Western Digital, we are using Jira v8.5.4. Yes based on certain trigger conditions i like to file a bug with specific attributes for each error. Its not with same information. I am going through this automation on Jira. Thanks!
You're welcome Sathish, then you'll probably find all the information you need on this tutorial.
Tell me if something is still unclear after that !
